classicconnection »
https://forums.nicoclub.com/classicconnection-u147247.html
Thu Nov 12, 2009 11:32 am
Yup, did push the button and replaced both switch and button. Now, how about this? Since I had to re-install the dash back to rear lights wiring loom, and connected up all the wire connectors to lights, fuel pump, gas gauge etc, they all work. When I plugged in the big connector with the 10 mm bolt, everything started to work and, the headlights popped up. So, doesn't that indicate the circuit is ok; just the stuff up under dash is suspect?
