pop up headlights won't go down
s13drifterbabe
Car: s13 fastback
Both my pop up headlights just quit working, it seems like it could be an electrical issue? They stay up all the time now. I have no idea how this happened because it was working perfectly until now. Pressing the headlight switch does nothing. I pulled the switch out to check the wiring plug and it was fine. I checked the 5 AMP headlight fuse under the dash and it was fine. Is this a common problem? Any ideas on how to fix this? I have searched this forum and other 240sx forums with no luck. I can't even search the word "pop up" because each word is less than 4 characters.
Fenvy
Car: 2005 350Z Base 6MT
did they stop working at the same time or one side at a time? if it is one side you probably have a broken headlight motor and I have something to sell to you
s13drifterbabe
Car: s13 fastback
They stopped working at the same time.
Fenvy
pop your engine bay
notice how next ot the pop up lights there are 2 things that stick out. pull off of the cover and you will expose the knob, turn it and see if goes back down eventually
s13drifterbabe
Car: s13 fastback
Loveless wrote:pop your engine bay
The lights will go down if I turn the knob, but how does that get the head light switch on the dash to work again?
s13drifterbabe
Car: s13 fastback
Am I the only person who has this problem?
moegenki
Car: '93 240sx Hatchback
It could be your relays under the hood. I think it was called H/L RET or something along that line.
