Postby
love-240sx »
https://forums.nicoclub.com/love-240sx-u52517.htmlThu Dec 28, 2006 12:37 pm
the problem is the headlights, it can pop up, but it won't go down. i have played with the relay but still nothing change. do you guys know what's wrong with it? tahnks
Postby
DevilMB3017 »
https://forums.nicoclub.com/devilmb3017-u47101.htmlThu Dec 28, 2006 12:58 pm
Are you hitting the side button or when you turn the lights on/off?
The button just pulls right off the console with a little twisting, make sure none of the wires are cut. Did you check all the fuses? They're in the kick panel and in the engine compartment box in the very front passenger side by the battery.
Postby
love-240sx »
https://forums.nicoclub.com/love-240sx-u52517.htmlThu Dec 28, 2006 1:32 pm
the problem with the headlight is that when I turn on the headlights it pops up and lights, no problem. when I turn it off, the lights turns off, but the headlight stays open. The button that you mentioned before is the same, the headlight pops up but won't go down. I have checked most fo the realys with a battery, and most of the fuses. thanks.
Postby
S13srdave »
https://forums.nicoclub.com/s13srdave-u160363.htmlWed Feb 15, 2012 11:44 am
(I know I'm bringing this one back from the dead but) Anyone ever figure this out? My fuses and relays are good, but headlights won't go down, unless I do it manually. button on the dash makes them pop up, but won't make them go down.
