smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Thu May 08, 2008 10:17 am
You should receive instructions with your Pop Charger. For the actual installation, all you really need is a 10mm socket and a phillips screwdriver (not to be confused with the drink).
Things to expect. Expect to take some time to attach the foam pieces to the heat shield. My recommendation would be to wear some gloves as I cut myself trying to do it. The foam pieces are the hardest part of the process.
No shortcuts really. Its pretty simple and straightforward.
I did a write up on installation to kind of compliment the instructions you get, so if you want that, let me know.
