satown210 »
https://forums.nicoclub.com/satown210-u230736.html
Sun Jul 15, 2018 12:12 pm
Yes, I have a solid signal now. The color does not matter. When you get the replacement antennta, remove the rubber gasket. It just sits on a lip around the antenna. You can now gently pry off the painted cover. It just snaps on. I put my replacement antenna on without my painted cover so I could see the entire gasket and make sure it sat flush so I didn;t have to worry about leaks down the road. After I was satisfied it was in place correctly, I just snapped my original painted cover on.
