Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Sat May 14, 2016 7:20 am
persists in my 1992. I have new deatshcwerks replacement injectors, new fuel pressure regulator, new fuel filter, fairly new fuel pump. Problem is worse when car is not warmed up, on sudden throttle opening, it tends to bog, sometimes backfires, or bucks. If it happens, I can let off, then open throttle again, and it will pick up and run, but it is really too cold shouldered.
Before replacing regulator, at times it would barely run. Now it runs well, except at times when I really need it, under quick throttle opening.
I'm beginning to suspect fuel pump controller, IIRC, fuel pump may run at three different speeds depending on load conditions.
Is there any good test for controller?
Thanks, Drake.
