cccpman »
https://forums.nicoclub.com/cccpman-u36612.html
Sun Jun 24, 2007 9:02 pm
I agree, had similar problems with a failing pump. Big sign to confirm would be a buzzing sound coming from the right rear of the car. Turn the car on and listen for it (head in the trunk, or from the right rear passenger seat), even if its not the pump the car probably will be needing a new one shortly so its definitely a good thing to replace. Be real careful if you do go to replace the pump, its too easy to bend the floaters arm and that will really throw off your tank readings
As for the plugs, its a real inexpensive fix (and its not such a pain in the *** after a couple replacements).
Oh well, see if you can hear the pump buzzing away
