Very bad for the engine, all you need is 2 minutes to let the oil circulate and coat all the moving parts. Revving the engine while dry is very very bad. Your engine won't die is you just start and go but you are definitely shortening the overall life of the engine. Even in the warmer months you need to let the oil circulate. You can still drive with the blue temp light on which you obviously do. Some people like to "warm up" their car first but it's just a waste of gas. 2 minutes is all you need.Jerky_san wrote:I dunno if its bad for the engine... but personally i just get in and drive the thing.. Only car i've ever really "warmed up" was my superbeetle but even then for around 20 to 30 seconds tops.. Just enough to get the oil flowing..
I've ridden in a car with you.. Granny... HAHAHA!! yeah right!vududoc wrote:driving habbits are that of a granny.
Modern multiweight oils flow well and offer full protection at low temperatures. The oil pump is positive displacement therefore you have full oil pressure and full flow to all parts within a few seconds.The Edge wrote:
On the A/F alpha, any reading between 90 - 110 is acceptable, with 90 being rich and 110 being lean.vududoc wrote:I thank all that have provided input on this thread.Motoguy128-definate thanks on that input on viscosity.
Just a bit to add to my first post.... the thread was to see if others were having this problem.
Here is some background- car was purchased used at 9300 miles on a trade in. Car had qtr tank and i gassed up to 3/4 after sending it out for mods. Gave the wife the car as a early xmas present (im still walking though lol) and checked the tripmeter to see if it actually got the advertised mpg. a true 14mpg and yes my math was correct. I finaly got the car back from the wife and was able to run it on consult 2 only to find a whopping 87 on A/F alpha reading (should be 100). A/F was reset this pm and car driven over 36miles (city/hwy comb.) with out a budge on the needle
hope this helps others out if they see something like this. Essentially this is caused by idling too long and poor fuel quality from previous owners habbits being stored in ECM. it would have taken quite a bit to get this all resolved over tank loads and a quick reset was the easiest.
Thanks again for you inputs.
(hey eikon long time no see ...currently working on getting the IMPUL supercharger in the states for this car. ill post a seperate thread on this car...and most of my projects are other cars this is the "wifes car" he he he)
my mistake i believe i should have been speaking of long term A/F.nissantech06 wrote:
Another stat that might work is looking at the long-term short-term fuel trims...if your long-term fuel trim keeps showing that it's trying to lean the mixture out, you know you are running too rich.vududoc wrote:
Glad it seems to have improved, let us know after a week of driving to see if she behaves. Then I'll add this to the FAQ as a means for troubleshooting mileage issues. Actually, I'm going to add it now in case I forgetvududoc wrote:I thank all that have provided input on this thread.Motoguy128-definate thanks on that input on viscosity.
Haha, so true.Scottneon wrote:I don't really warm her up just like a minute or 2. It would be longer if I got my lazy *** out of bed on time...
Isn't Olney like continuous bumper to bumper traffic? To get good mileage the vehicle has to actually move. I'd expect my mileage to be cut in half if I had to move back to central MD.ALF wrote:I've been getting lousy MPG too. I have an 07 CVT, purchased July with 4300 miles. My current tank looks like it's only going to get about 200 miles on it! I was getting about 28 miles a few tanks ago. My mom, who has an 07 automatic, is also getting horrendos MPG.What's the deal?
Olney? No way. There's regular traffic but not bumper to bumper. Especially at the hours I commute. I'm going 50 till I get to my destination.bikeman wrote:Isn't Olney like continuous bumper to bumper traffic? To get good mileage the vehicle has to actually move. I'd expect my mileage to be cut in half if I had to move back to central MD.
David
At 50 mph, my Versa CVT will get approx. 35 mpg. Good luck with finding a solution. And let us know if you do find a solution.ALF wrote: I'm going 50 till I get to my destination.
