landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Tue Feb 18, 2003 10:58 pm
Injectors -- "a lively crew of gremlins making power for me." LOL -- a 911 driver who cares becomes adept at sorting out "good" noises and "bad" noises. Wonderful diagnostic tool for the developed ear. I was looking for a 911 when I got my Q. Haven't completely abandoned the idea . . . the last one we had was a brute. In a good way.
Me, I've never heard a Q's injectors over the sound of the motor that I know of. A mechanic's stethescope would help sort out injector and HLA noises in short order. Injectors are a plausible source of the noise, but I have no experience.
Little details aside, HLA corresponds pretty closely to the hydraulic lifter in an OHV design. It's called a different name in the OHC design. It's a similarly constructed piece that serves at least one of the same functions. A noisy HLA is about the same thing as a "sticky lifter" from the old days. Not much to worry about unless the noise is excessive or remains loud after warmup.
The remedy is iffy, and gets iff-ier as the HLA gets stickier. There's often not enough oil flow through the HLA for *any* solvent to disolve the sticky varnish in just one session. Or two, or maybe five. If it's a noisy HLA, I think it's most likely something to live with until the motor expires of something else, like valve seals, which sadly, aren't economical to repair. (You'd be surprised such a simple piece can spell doom for the motor -- it's wild. More reason to keep up with oil changes!) You could replace HLAs, but that would be prohibitively expensive, involving as it does removing the cams and timing chains.
I suggest the lightest synthetic oil in the recommended range, and a few oil flushes with BG Quick Clean, hope for the best. That's what I'm about to do with both of mine.
I'm glad your car has a good oil-change history. Nice to hear that the oil is so clear. Maybe the noise *is* injectors? Any indication of whether he used mineral oil or synthetic? Synthetics tend to leave much less varnish.
" warm up the car every time and it was a mixture of surface and freeway drivin', a full tank barely got me 225 miles in total."
Yup, I would investigate that kind of mileage with a warm motor. You're right -- something could be amiss. I wouldn't be terribly concerned, but I would want to know that everything was working right.
Thought: the O2 sensors are electrically heated during warmup. You might check that circuit. Overall, really bad O2 sensors (they fail gradually) will penalize you about 2 mpg on the highway after warmup.
Static timing is a possiblity. The timing chain stretches to a point with mileage and will cause ignition timing to back off by 1 or 2 degrees in 100K miles. In the other direction, too-far advanced timing will cause ping and make the ECU back off the timing. Because the ECU backs off in *chunks*, it's best not to have timing on the ragged edge. Better a couple of degrees away from optimal than have the ECU dropping chunks off and gradually adding them back.
Oh, but wait -- you have emission tests, 91 octane, and oxygenated fuel in LA, right? Gas less than 92/93 octane can cause ping/retard/reduced mileage. Oxygenated fuels carry a mileage penalty. As always, Dennis' observation, this time about "1989 gas," is well taken.
As for another possible source of ping/retard/reduced mileage, it's common for the EGR passages to be *completely* full of carbon. Easy enough to rod out. I may be wrong, but I think your CA emission inspection tests only idle emissions. An idle test won't catch a malfunctioning or clogged EGR, because the EGR functions only at part-throttle cruise. Combine a clogged EGR with an ECU that watches the knock sensors like a hawk, and that could be the whole problem right there. Even if it's not the whole problem, I'll bet your car would benefit from having the EGR lines and passages cleaned out.
"i had a 560 sel mbz that got better mileage than the q, i think, but you know what, i love driving q."
The only car in recent memory I would like to trade back to was a positively brilliant '98 MB E430, but the depreciation would eat me alive at $15 - $25 a day. (The Q depreciates about $2.50 - $3.00 a day.) The Benz, even 6 years and 140,000 miles younger, just isn't 10x better than the Q. Gas is such a small part of the overall cost-of-ownership.
