TunaFish »
https://forums.nicoclub.com/tunafish-u26213.html
Mon Mar 07, 2005 12:35 pm
I just recently picked up my 240, and the Blitz BOV really isn't functioning very well.
Despite blitz claims to it being one of the loudest ones on the market, it is barely audible and sometimes with low boost it doesn't even open. (Though you can hear the compressor surging.)
I tried adjusting it, but it didn't seem to make a difference from going all the way tight to all the way loose or anything in between.
It has vacuum, though I do question the goofy swivel fitting that blitz uses?
I don't think I have a boost leak, I hit 7psi with out a problem and idle at about 18kg.
The only thing I have found is that blitz sells two springs, one for low boost and the other for high. Is it possible I have the wrong spring for such a low setting?
