The o2 sensors or maf could be starting to go out without throwing codes and I got my MPG info from http://www.fueleconomy.gov/.Pogophil wrote:thanks for the reply.
o2 sensors and maf sensor would trigger codes if they were faulty -- but there were no codes.
i didn't check the mileage myself, my dad did. let's assume he calculated it correctly.
fyi -- the 97 j30 was rated 18 mpg city/23 hwy. his 12 mpg is considerably lower than that.
i've already cleaned the maf -- didn't help.puck wrote:Just thought I'd chime in too. I would not rely on the MAF or O2 sensors to throw codes for the type of problem you're having. My car did not start reliably and had poorer gas mileage (J30's gas mileage suck's even at its best) when I first bought it than after I cleaned the MAF sensor. The difference in starting was striking. I later realized it helped with gas mileage.
I would definitely clean you MAF. Its so easy and could improve your performance.
