Is there a noticable location where the vibration is coming from? Does the car seem to take off after 2500 rmp? Pull the connector from #6 coil while running any change ? Smell of gasoline i would start looking for a fuel leak especially at the mpg your are getting. See if you can take a peek (feel moisture) at the small piece of hose that connects the fuel rail underneath the plenum [_]. Any codes? Grab a multimeter and check those injectors.ZX-Smoov wrote:HI everyone,
I've been peeking around the forum for about 3 weeks and I'm a 2-week owner of a 92 NA 2+2 (Ya me!).
I'm experiencing poor acceleration and vibration around 60mph and above. Is there a visible inspection to confirm a driveshaft problem? I plan to do some of the other tests for fuel and air pressure.
Gas milage is terrible (less than 30 miles on a half tank) and there's a smell of gasoline. HELP!!
Work done so far:
Cleaned K&N Air Filter
New NGK's 6-11b
New fuel filter
New shocks
Need to check the CAS and timing. I'm not sure if #6 coil is good or bad.
Building up the nerve to pull my plenum and check injectors.
Any thoughts or ideas?
You guys have offered some awesome advice- Great reading!!
No change on #6 means it isn't firing. Could be bad spark, or bad fuel injector. Since you smell gas, maybe bad spark?ZX-Smoov wrote:Had the garage for a few hours Saturday and here's my update:
All 6 coil packs gave 1.0 on the multimeter
Pulling connector on #6- No change in engine RPM's
ECU- threw code 34: The Knock (detonation) Sensor
MAF is responding- car shuts down when pulled
Thanks for the video link on clamps!!! I made between 2-5 turns on most of them, except for those on fuel filter from my previous install.
Planning on ordering a knock sensor and sub harness for a relocation install on top of engine just in front of the firewall. Anyone have any positive or negative feedback on the proposed switch?
Also, anyone have a good explanation on pinched o-rings and where they are located? I don't know if this is a concern, but I'd like to learn more about the Z!
Thanks for the shared wisdom and professonalism on this forum!!
Uh oh... don't know if that is a big or small issue. Others might be able to chime in. I recently read somewhere where there is a way to get the car to give you codes on the auto transmission too that is different than the ECU. I haven't done it but here is the link -ZX-Smoov wrote:Hi Gang,
I am concluding that my problem also has much to do with my transmission. I put in a bottle of transmission treatment and it ran much smoother. The next day I found a small puddle of transmission fluid in the driveway the car ran rough again.
Hi Ziggy,Ziggy1621 wrote:Did you put new injectors in or used? If used, ohm that injector. You can also do the 'click test' with a screwdriver. While the car is running, you put the tip of the screwdriver on the injector and the other end up to your ear to listen for clicking.
You said you put a new sub harness. Which harness are you referring to?
Check for corrosion or broken wires on the coil connector for the #1 cylinder. Pull the coil pack and plug. Have a buddy turn the engine over while you ground the tip of the plug to see if you have spark.
If that fails, do a compression or leak down test
Hey ThisIsSparTTa!ThisIsSparTTa wrote:Let's take a step back. If you're not getting spark on #1, then start there. Are you sure you're getting spark on other cylinders (ie: you're performing the spark test correctly)? I had to learn that the engine needs to be running to test for spark...and also to be careful where and how you're holding it.
We went around and around on this stuff on my friends car. Start with the PTU test posted in this forum. From there I would inspect the PTU subharness as it will often corrode and cause problems. Many people cut that subharness out and solder it straight as its not necessary. Then I'd check continuity from PTU to Coil Pack Connector, then Continuity from ECU to PTU. Even if all of that checks out, you could still have an issue in one of your wires as you can still have continuity if just 1 strand is connected. That's what ended up happening with my friend's car, we tested EVERYTHING. Finally he took it to the local Z shop and they figure out the wire from PTU to the coil pack was bad, and I guess bypassed it.
