Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Mar 29, 2008 5:39 am
If a non active used 94 needs $3,000 at minimum in repairs, then assume an ACTIVE 94 Q might only need $5,000. The $2,000 difference is netting out the $500 is standard shocks vs $2,500 on active.
A major question is when will either version need a transmission replacement [$3,000] and when will AC need rehabilitated[ $1,000-$2500], same with valve covers, plugs, plenum hoses, knock sensors, [$2,000] and injectors.
Differentials usually need replacing around 200k. [$750-$3,000]
Purchasing any 14 year old used lux V8 is just the introductary price you pay to spend at least that amount again over a year or a few years.
Buy cheap [depreciated] and repair well.
