Polyurethane FRONT lca bushings, anyone tried?
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
Im redoing the front end suspension, new balljoints and stabliizer links and struts. And saw that 4x4parts offers a bushing kit for the front LCA front and rear bushings. Has anyone tried it??
Im also looking to order bushing for the upper rear trailling arms, but dont see a specific kit, are they the same size as the lowers??
They also used to have a stainless brake line kit on there, do they not sell stainless lines for 99+ anymore??
:inout: :inout: :inout: :bs: :bs: :inoutgay:
Thanks for any help, should be a good summer for mods!!
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
I can get stainless steel lines if you cant find them there.
I would be really interested in the urethane bushings in the rear trailing arms, if you find out let me know. I could also possibly have bushings custom made but not sure how cost effective it would be.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Seems like you hit perfect timing on asking this. I just had my car apart for 2 days, just finished putting everything back together tonight. I installed poly front lca bushings from 4x4 parts, new kyb strut boots, cv boots ( one had a small tear you should also consider doing this when you have it all apart if you havent ), Moog front swaybar bushings, moog front swaybar links, moog rear swaybar bushings, didnt change rear swaybar links, seemed fine for now if they do go bad its like a 40min job.
I will be posting a thread tommorow on this but as of my first 30min drive when i put it all back together, get the poly bushings, but also replace all the other stuff. The handling is even better then it was.
CanuckQx4
Cool cool
I just didnt know if the fronts even wore out on r50's like the rears anyways
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
carnal_c30: Lotsa folks, including me, have done poly bushings in the real trailing links. It's generally considered a good idea.
4x4parts.com has a kit.
Chuck
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
thank you! for the info!
Alfredo24.pr
Car: 2002 NISMO Turbo Pathfinder LE
miamiheat3332 wrote:Seems like you hit perfect timing on asking this. I just had my car apart for 2 days, just finished putting everything back together tonight. I installed poly front lca bushings from 4x4 parts, new kyb strut boots, cv boots ( one had a small tear you should also consider doing this when you have it all apart if you havent ), Moog front swaybar bushings, moog front swaybar links, moog rear swaybar bushings, didnt change rear swaybar links, seemed fine for now if they do go bad its like a 40min job.
Seems like you love handling parts for your path lol, looking forward for the thread!
