mtcookson wrote:Sadly, there isn't a whole lot out there for the 3rd gen but there is some... This guy makes some real good suspension parts for the 3rd gen but I'm not sure if he's still making them or not:
http://www.blehmco.com
Here are some poly parts I know of:
http://www.courtesyparts.com/M...3117G
https://www.whiteline.com.au/s...BNF18h ... /s...BNR14
Noltec:N44912 Camber bolt kit F 1 12mm diameter $76N51778 Control arm - inner front F 1 $43N51451 Control arm - inner rear F 1 $80N21014 Sway bar - link F 1 $18N61452 Control arm R 1 Incl. crush tubes $106N61631 Lower trailing arm R 2 $45N21014 Sway bar - link R 1 $18N22112 Sway bar - mount 18mm R 1 18mm - measure bar size $14N61631 Upper trailing arm R 2 $45
http://www.oztek.us/noltec.php?mid=25
I have most of Matt's stuff on my car. Awesome stuff!! You will not find better rear sway bar links anywhere.
What bushings are you looking for?
For most bushings you can measure them and Energy Suspension has a universal chart that goes off of measurements.
Front Sway bar - use early 90's Mustang
For Front Sway bar end links just measure them and Energy has them.
For control arms there isn't any but you can buy 95-99 Maxima they can be cut down to match 3rd gen.
If you order Suspension Techniques or Addco Sway bars you get bushings with.
For anything else just measure and they proly have something close.
For engine and trans mounts most people get polyurethane and fill the stock ones
Also check shox.com for suspension parts. Thye have the best selection and best prices that I have found
