Assmunke wrote: iv'e been reading up on this in other forums, but i was wondering if i can get away with replacing my worn to **** tension rod bushings with some whiteline polyeurethane ones. the problem is that i read they can crack your control arm due to restricted movement or something along those lines- however i don't drift and the car is mainly a daily driver so i was wondering will i be able to get away with these without breaking my ****?
i read through several threads on this subject, and i've come up with several conclusions as to why this happens...
1. overtorqued tension rod bolts.
2. fatigued lower control arms.
3. bad installation. tension rods are supposed to be torqued down with the car on the ground with its full weight (all fluids full including a full tank of gas, spare tire, jack, tools, etc.). once you torque it down, it's not going to move. if you torque the tension rods with the car elevated, it's going to bind where it meets the lower control arm when you lower it.
4. lowering your car. i'm no suspension guru, but it seems to me that it loosening the tension rod bolts before you lower your car then retorque them at the new height would alleviate a lot of stress.
i ran whilteline poly tension rod bushings on my fastback for 2 years and i had no problems whatsoever.
-demetrius
