locoluna825 wrote:yoru supposed to remove all 4 of the metal rings after you have melted the bushing out, and DON'T BEND OR DAMAGE THE METAL TABS!!!
the 4 metal rings you remove are from the front set of pineapples. the metal tabs are fine on my car.. one had broken off though on the car already. I'm sure ill be fine.
the rear ones stay in place i believe. i polished out the rubber from the rear ones and the pineapples fit in them just fine, so don't remove the rear outer sleeves!! if you do, you need to get yourself a new subframe because the pineapples will be loose in them.
thanks for confirming that the diff cups are the same on yours, i will let that rest now.
