elwesso wrote:What im not sure about is what the poly frame bushings are supposed to do?? Are they just supposed to hold the sway bar tighter???
No bushings hold the bar tighter, they should have some lube between the bar and bushing anyhow, I've always used Teflon tape. Poly bushings are stiffer than rubber ones, so they'll just flex less, the D brackets hold the bar and that's all they do. No amount of tightening them will make the car handle differently either, but adjusting where on the bar the endlinks mount as on some bars will make it stiffer or softer, and the length of the endlinks can make a difference too. You should talk to this guy at Saner Performance Fabrication, they can make just about anything you want for your sway bar needs, including the bar itself. I dealt with him a number of years back and bought some stuff from him.
Did you get a full Energy Suspension kit for the car? I was actually wondering if they make one for the Q's the other day.
