Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Sep 01, 2003 9:38 pm
On Nissan rear design, you have double end links with 4 bushings each and the center supports.
Not unusal to see a tapered up slack of 1/8" x 4= 1/2" [in each direction] when this is multiplied by the end link coupling point [middle of lower a arm] divides by 4 ......so 2" of body roll before the bar is 100% coupled.
There is some action of the rear bar but probably less than half during the 2" roll and nothing [very little] in the 1st inch of body roll.
A 20 mm bar would be expected [calculated] to resist roll by 40x3"=120 pounds in a 3" sway..........but probably only provides 60 pounds due to rubber bushing compression [depending on bushing age and tightness]. By factory design to reduce road vibration thru bar to opposite wheel.
Solid urethane/nylon/prothane still has some small give, maybe 10% vs 50% for rubber................120x 0.9= 108 vs 60 oem bushings.
Roughly the same as increasing bar diameter from 20>...22.5-23.0mm.
Many cars like early BMW had weak attachment points for bars and end links. Things would bend/break with stiffer bars or urethane.......however the Nissan/Q/J rear points are very strong [compared] but sometimes the oem end link rod needs to be upgraded..........try the oem if you bend it the answer is obvious. Usaully only greater than 23 mm hollow rear bar will bend it but solid rear bars might if coupled tight enough.
Don't go rock climbing with urethane bushings.
