SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sun Feb 06, 2005 7:39 am
Chmercer,
No you haven't called JIC and talked to Randy and had him explain wholesale pricing and buying structure.
JIC can add the Z32 rear fork(if you use Z32 rear spindle for Z32 rear brake job) in place of the S chassis so there is one more reason to check them out. The Z32 fork is not available in the US for distribution. JIC will air freight them from Japan. No more guesswork.
My military friend has had the JIC FLT-A2 for..ohhh... one year now, no problems, no hassle, and we know who to call if / when we have a problem.
The problem with the other thread you read is that Bostons13 obviously knew who to call, he even said so. Looks more like he had an axe to grind, publicly, more than he was upset at his suspension performance. Everybody used to say TEIN would rust and they are terrible. Truth is they are too affordable to ignore. Whatever shortcomings I do encounter with JIC, will be a good learning experience and can be posted here for documentation.
So next set will be JIC FLT-A2.
