Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Nov 04, 2005 5:30 am
Balanced forward?......... Not compared to most 4,000 pound cars...........why the rear pads wear fast compared to others. Why the Q as new could stop in 129 feet [besides the XGTV 170 treadwear tires].
The old Q is maybe 65% front [depending on the speed which brake are applied.............pad friction coeficient varies with speed of application.
Antidive suspension, VSLD, etc vs a solid rear axle.
Anyway the J30 rear rotor is just vented vs solid.............not much difference in weight so the peak temperature rise will be just a little lower unless sustained when the air flow will help offset rise [mountains?].
80/60 to zero should not change [time to short].............anyway tires are always limiting factor since ABS is tuned to match fast wearing tires........every ABS cycle lengthens the distances significantly.Pads rotors don't gain more than 200F in a single 80 mph stop.........far from 500F when weird things start to happen with pad nonlinearity.
Why you can get 115 feet or 130 feet or all the way up to 150-175 feet with BAD tire choices! Just from 60 mph
