pointless to run over 6k rpm
wildacexxx
Car: 2002 Q45 nav sport
i was driving today and pushed it a lil. i feel that the t25 at stock boost doesnt provide much past 6k rpm. am i right? should i just shift like at 6 or 6.5k?
S13240
I feel stock boost should be 10 psi and not 7psi. But you're right
wcxbp240
Car: 1993 240SX SE SR20DET
Similar set up, similar concerns...What gives?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
yeah most SRs with the stock t25 and stock boost seem to have boost drop off around there. my setup is exactly the same.
JesusLikesKFC
Car: 91 240sx, geo prizm
never a bother for me.
wildacexxx
JesusLikesKFC wrote:never a bother for me.
not saying its a bother.i know that its cuz of the small turbo and low boost. just saying that would the car be quicker shifting at around 6k or 6.5k.
highmilehatch
It has alot to do with the stock camshafts as well.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Just shift at 7500rpm.My car feels alot faster when i do.6000rpm is WAYYYY to soon..Ill shift at 7000rpm in 4th gear and sometimes 3rd..My sr loves to be rev'ed up to 7500 though
JesusLikesKFC
i ussaully shift at 6500. no point in reving that high for me seeing as it makes no more power. then again im paraniod i might **** up my valvetrain that high up.
nzmoman
Car: 240sx 2 of em' and always lookin for more
9240sx wrote:Just shift at 7500rpm.My car feels alot faster when i do.6000rpm is WAYYYY to soon..Ill shift at 7000rpm in 4th gear and sometimes 3rd..My sr loves to be rev'ed up to 7500 though
it may feel faster but unless you have some head upgrades it aint. your shifting after your car has exceeded its powerband. all thats good for is barking the tires and drawing attention to yourself on the street unless your drifting. I laugh at people who think that getting in to the redline is the fastest way to drive.
I think the stock powerband tops out around 6200-6500 I can never remember...you should be shifting in that range or just a hair over it. youll know cause the car doesnt pull as hard and the tach stops climbing as fast.
Modified by nzmoman at 4:13 PM 7/21/2006
Blown240sx
Car: 1996 240sx
The stock setup up falls off around 6500 I proved it at the track. I ran much faster times by ****ing early. This is mostly do to the T25 and the stock Cams. Upgraded cams help a lot in top end and bigger turbo doesnt fall off like the T25.
hpmachine
Car: '05 EVO8 + '95 240sx
yeah the stock t25 at stock boost really maxes out at about that point... when the wastegate opens you may as well shift hahaha
Vr6WantSr20det
i shift at 7000, there isn't too much pull after that. Reving to 7500 is a bit pointless as the tiny t25 drops off. But wutever makes u feel better. If u wanna know for sure, go to a dyno and see where it drops off. But 6000rpm is a bit early.
ser2102
Car: 91 dead. 90 getting did
if you shift too soon, the next gear you hit will no be in the powerband. gotta find the right mix of not shifting too soon and not too late either.
wildacexxx
found mine, just above 6.5k. it revs fast with all the lightened crap i have.
Tulsa_S-13
Car: 1991 SR 240sx
hpmachine wrote:yeah the stock t25 at stock boost really maxes out at about that point... when the wastegate opens you may as well shift hahaha
So I'm guessing your joking....
Uhhhhh so when exactly does the T25 make full boost on the SR? I don't own one currently so I'm not sure myself but I'm sure its around 2500-2800? If you shifted when the wastegate opens youd be shifting at the time the turbo makes full boost lol
nzmoman
pretty sure he's talking about the decline in boost that will happen at high rpm. or at least I think he is
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
Study your Dyno sheet and see where your max torque is, rev past that to the point that when you shift you end up right before that (enough before that to give the turbo time to spool), then your turbo will spool up at its most efficient so when the next gear catches you will get the most out of the thing that makes you go... Torque.HP keeps you at your speed TQ gets you up to speed
Silvia240 24'7
Car: 1990 240sx coupe
From what I noticed that the stock powerband on an sr20 is more like 7300 to 7500 6200 is weak sauce
Silvia240 24'7
^^^^^^^^^ my reply is actually in the quote like a noob but I totally forgot I just did a couple of upgrades including cams to my car so my powerband is closer to 7000 my bad sr20essex I totally forgot I've just upgraded .
SlowS12
Car: 87 200sx
psshhh.. see this is the point in time where you UPPP the boost.. then it wont feel like the boost falls off ~6k..
wildacexxx
i think i should get the car running 100% before i boost it up. i still got a couple of bugs to fix before i do.
Tulsa_S-13
Car: 1991 SR 240sx
Silvia240 24’7 wrote:^^^^^^^^^ my reply is actually in the quote like a noob but I totally forgot I just did a couple of upgrades including cams to my car so my powerband is closer to 7000 my bad sr20essex I totally forgot I've just upgraded .
What cams are you running (duration, brand)?
