DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Mon Dec 08, 2014 8:52 pm
Welcome to NICO!
One of the most important things to do is a self-check regarding just what kind of an experience you are looking for in a Z32...and by this I mean not "I want a fun fast car" and the like, but more like "I want an easy to own sports car" or "I want a cheap sports car" which you hinted at mentioning the Z is now in your price range. The Z32 is neither of those things- it may be less expensive than many to purchase, but is that way partially because it is hard to maintenance and costly compared to like vehicles.
This comes to play in the form of maintenance beyond the 120K mentioned above, such as servicing the injectors/connectors/harness, turbos (likely at some point) and associated plumbing/hoses, vacuum hoses and wiring connectors as well as many of the sensors and such the connectors are connected to. The car tends to heat bake it's wiring harness and connectors and many components, and often has oil leaks and boost leaks to deal with. This is just the tip of the iceberg- it's a 20+ year old twin turbo performance vehicle and finding reliable mechanics for it is difficult at best and expensive, and the parts are also on the upper end of costs not including the turbo-relate items, which definitely are spendy.
Bottom line is unless you find and buy a pristine '95 or '96 TT, you will have a lot of maintenance to do and/or plan for in the near future, and even with one of those two years, will want to be ready for those costs and also have access to a Nissan mechanic and/or learn a LOT yourself quickly if you are mechanically inclined.
Moving on, the best years to buy are 1994 and 1995, due to new style injectors/harness/fuel rail and a few other minor changes.
The 1993+ all have airbags but 1996 has less power due to no variable valve timing, but has all other upgrades.
Also, the 2+2 model has a number of different body and chassis parts due to it being slightly longer.
No real other reasons except the smaller 27mm brake calipers in the front of the '90 model to buy one year over another, there are several small differences to many of the year models but overall nothing major changed beyond what is noted above.
Other details that will make a difference are the less previous owners, the better- same as less miles the better (but more costly).
Also, look for an stock unmolested Z unless you are SURE of what you are getting (and how could you be, here asking questions?), and plan the necessary maintenance FIRST before and mods or other changes to the car.
DO NOT BUY AN ENGINE SWAPPED Z, PERIOD. In your case this most likely will NOT work out well for you.
Also, do not get one with an electric fan setup, be SURE it has the stock setup and is functioning correctly as cooling is often an issue with used Z's. Often a refreshed stock clutch fan with new belts/hoses is a part and parcel to a true full 120K service which includes the water pump.
Try to find a knowledgeable Z32 guy if possible also to help you look at any potential Z's, as owning one DEFINITELY makes you aware of what to look out for and where the problems are.
I'm sure there's more but these are probably the biggest things to be sure about before you purchase a Z32TT.
