PO400 or P0402, EGRC-BPT
Aptus
Car: 1998 Q45
I thought I'd share a recent issue and fix on my '98 Q (158k miles).
I got a check engine light but the car was running fine. I reset it a few times but it kept coming back. I bought an OBD code reader and it gave me an 0400 EGR code.
The car was running fine, but I had noticed a slight "burning" smell in my garage a few times and even inside the car once or twice. It wasn't strong, and I wasn't sure where it was coming from.
I got under the hood with a flash light and noticed a slightly dirty area at the back of the plenum, around the EGRC-BPT valve. It wasn't the kind of dull, dusty dirty look everywhere else. It was dark and slightly carbon-like/oily.
I then found my culprit. There is a small (roughly 2") rubber hose at the bottom of the EGRC-BPT valve. The service manual says it provides exhaust pressure to the valve. So obviously it gets hot from exhaust gas and the hose was completely rotted/split. (by the way, the shop manual says the trouble code for the EGRC-BPT valve is 0402, by my scanner had given me the 0400 code)
So the exhaust gas was causing the slight burnt smell and the dirty area on the back of the plenum.
I replaced the hose and reset the code and haven't had a problem since.
I highly recommend this $.50 piece of rubber tubing be replaced on everyone's Q as a maintenance item for cars with more than 80k miles or more than 6 or 7 years old. Why wait for a problem to happen. It took 10 minutes to replace.
-Don
Q451990
Good to know! Supposedly this is a special rubber hose that can deal with the heat when you buy it from the dealership, so if you're using over the counter vacuum hose, you might keep an eye on it.
Heath
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
got a photo?
Aptus
Car: 1998 Q45
Can someone guide me on how to get the picture into the posting? I clicked on the "image" icon, but that didn't seem to help me in any way.
my12by60
I have the exact same symptoms as the original poster --- slight burning smell and po4000 code. Car seems to run fine otherwise. How do I locate the hose in question? Do I need the hose from the dealership or can I use some vacuum hose from O'Reilly?
my12by60
I was able to locate the hose that Aptus referred to in his original post. Sure enough, my hose was split clean through in the section between the nipples at each end. Here is a picture of the EGRC-BPT valve removed from an Infiniti G20. The part looks just like the part on the Q45. The picture shows the valve upside down vs. its installed position toward the rear of the engine. The short single piece of hose that comes off the bottom of the valve is the hose that rots and splits. I had some hose on hand that was the right diameter. So I just installed a new piece.
https://www.ebay.com/itm/EGRC-BPT-Valve ... :rk:1:pf:0
