jetroy240 »
https://forums.nicoclub.com/jetroy240-u85577.html
Thu Feb 05, 2009 11:01 am
For P0400 code, common problem is egr pipe clogged w/ carbon deposits specially to the intake manifold location, remove & clean only or replace pipe if too much deposits & can't be cleaned.
For engine dying, many possibilities, could be bad ISC motor & ecu, maf (need to see ALPHA) or just ecu reprogram only, depends on what ecu number u got. No other codes except P0400?
For abs light, u need scan tool to retrieved the abs code first.
Modified by jetroy240 at 3:41 PM 2/5/2009
