po340 code
InfiM45-RPMS
Car: 2006 Infiniti M45
good morning and how you doing
my car was shaking like it was going to turn off every time i stop at the red light but it wont turn off just shakes a little bit, then when i accelerate and get my foot of the gas, the car accelerate a little right after my foot is not in the gas pedal. then this code pop up PO340 camshaft position sensor. i was told to change all 3 and i did but the code keeps coming up and i get the same situation above after maybe a 40 min ride. we check the negative loose them up but them back but after 40 the code come back. i dont know what else to do i need some help please what can i do next please help thanks a lot
Double E
Car: '04 M45 Dark Blue., NAV
Non OEM sensors?
EdBwoy
Good morning, and welcome to the forum.
Which 3 sensors were replaced, as in their locations on the engine?
Look through the link below, and if you haven't tried this, also type in P0340 or camshaft into the search field to see the threads addressing related problems.
topic607101.html
