nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Thu Mar 06, 2008 8:45 am
It's not complicated. I used to have one when my car was turbo'd. I found a local guy who had a wideband to help me tune it. Tuning itself is very easy, so if you can find someone with a wideband or have the money to get one yourself, it's a good idea and fairly easy way to get a few more horsepower if you have significant mods. There is no way to tune without a wideband. The whole point is that you're optimizing the A/F ratio, so if you don't measure it (via a wideband), there's no way to tell if you're adjustments are doing anything.
If the only thing you've done is a little porting, I doubt you'll get much out of an SAFCII (or any other) tune. If you have some other mods (intake, cams, full exhaust, really the cams are the important part) then it will be worth more.
However, in your case it may be easier to get an ECU reflash done. Run a search, the details have been discussed and I don't remember them off the top of my head.
