Plz help
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
G35_Rider
Hi,
I'm new to this forum and need some suggestion. Currently own 04 g35 coupe black and planing to lower it. Any suggestion of which brand name I should use. Oh prefer adjustable one.
aukword1
Car: 04' g35, 04' rx8
tein coilovers or springs i would say
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Welcome to Nico!!!
Sorry, not a clue....but....if it had been a stang, would have said steeda...
But,
Welcome to Nico!!!
CYO44Baseball32
Car: G37S 6MT
tein s-techs, its what I have on mine
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I agree on the Tein. Spend the extra cash and get the coilovers with the pillowball mounts. Then you can easily adjust camber and caster. It will cost you just as much buying the camber kits for front and rear, and the less expensive set of coilovers.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Tein's with the EDFC. You can control the height from the inside of the car if you go with the EDFC.
Beancooker
tollboothwilley wrote:Tein's with the EDFC. You can control the height from the inside of the car if you go with the EDFC.
EDFC controls the damping, not the height. EDFC = Electronic Damping Force Controller
soul_hfk
Car: 2010 G37xS---08 QX56
any pics ? and welcome
zozoka1212
Car: 08 Infiniti G35x
Welcome to the forum.
JUst in case you wonder how to post pictures on this site zerothread/254009
zozo
tollboothwilley
Werd, my bad.
pae9132
Car: Modified 03 V35
If you don't have TOO much money then I would also suggest the Tein S Tech Springs along with the Tokico D Specs. Unfortunately on my 2003 G35 sedan I can't run the adjustment extensions into the trunk but u might be able to use them on the coupe. If you don't know what the extensions are you can find them at Stillen.com when you look for the Tokico struts. For you other guys with sedans like me you can have holes drilled above the rear struts which will lead the extensions into the area behind the rear seats so they will be hidden but I will have to look for the link to those directions. Good luck
tollboothwilley
PAE
what rims do you have on there???
C-Kwik
Beancooker wrote:I agree on the Tein. Spend the extra cash and get the coilovers with the pillowball mounts. Then you can easily adjust camber and caster. It will cost you just as much buying the camber kits for front and rear, and the less expensive set of coilovers.
The G35 does not use struts. As such no upper mounting plate for the G will ever be able to adjust the camber or caster. It requires adjustable arms.
pae9132
I guess I got my terminology wrong. I thought struts were the same as shocks. Well I use the Tokico D-Spec shocks and they are awesome. I also only have them set at the middle of the hardness. My wheels are Motegi DP10's. They actually look a lot better in person too. Especially right after they are cleaned up
etschell
Car: 2007 f17
aukword1 wrote:tein coilovers or springs i would say
you have to get tein. try to find a set on ebay
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
