Ladreik »
https://forums.nicoclub.com/ladreik-u121137.html
Sun Dec 28, 2008 4:36 pm
Check the throttle position sensor, and the connector that goes from it to the main harness. If there is a loose wire at the connector or of the contacts are not clean that could be another possiblilty.
My wifes car the other year had similar problems, lack of power... rough idle it would slow down to a max speed of like 80 on mountain roads. I checked the TPS, there was NO output signal. I replaced it and problem was fixed.
