ok well here is the story i have a 1995 s14 with s13 sr20det
the clutch went out so i replace it and drive it the whole next night . but tonight( 2nd day after the clutch was replaced) i was geting gas and when i pulled out after geting gas my car cut off as i was stoping at a stopsign and the car want start back. it will turn over but not crank. but when i spray starter fluid in to the t.b it will stay runing so i took this as it is geting spark but no fule right? the fule pump is new and working fine the fule rail and fule lines have plentty of fule in them so im thinking my injecters arent fireing i cant hear them turning on or anything so i need to know if there is a fuse relay or what controls the injecters and what i could do to see if this is the problem
anything you know about this would really help this is my d.d and its stuck at a walmart parking lot
thanks mikesardy
