PLZ HELP! must take out wheel asap, weird lug nuts!!
maku_gx
Car: 240sx
hey thereI bought this car a year ago, and I wasn't able to use it cuz it needed lots of work.now I'm about to finish it and I want to take out the wheels cuz I test-drifted the car and i wasted the wheels.I learned that I didn't get the wheels key, so I'm screwed. I cant find a key to fit this and I don't know what to do.
anyone have any ideas?picture the ideas the best possible so its understandable.thanks! ^^
here some pics of the fup lug nut
98s14inaz
Car: 2010 Nissan Titan Quad Cab
That looks like the ones from Vatozone...er...Autozone. Just buy a set, use the key to get them off.
maku_gx
Car: 240sx
ok ill try thatim surprised no one else replied with ideas thou.thanks dude!
gumby74
If that does not work, check out the local tire and wheel places. Discount Tire or mom and pop wheel shops. If they have a key, they may charge you a few bucks to take them off, just make sure to have lug nuts to replace them once they are removed.I have had to do that a couple of times. It's a bit time consuming, but cheap in the long run.
Slipstream
Car: '94 Sonoma, '90 300zx n/a
They make a tool set ($20 at Pep Boys). It's 2 different sized sockets with reversed threading. You just hammer the right one on, turn it counter-clockwise with a breaker bar. You might have to tap them on, turn , them hit them on harder to turn again. Works great though, used it this past spring on my eclipse.
maku_gx
Car: 240sx
Slipstream wrote:They make a tool set ($20 at Pep Boys). It's 2 different sized sockets with reversed threading. You just hammer the right one on, turn it counter-clockwise with a breaker bar. You might have to tap them on, turn , them hit them on harder to turn again. Works great though, used it this past spring on my eclipse.
hey thanks a lot for the feedback.
I'll go check it out today.hopefully ill find it.
r3v_v3ng3
Car: 91 fastback ka-t
try to see if a 3/8 or 1/2 inch extension fits in there. if so, hammer it in and loosen it. then just punch the extension out
240TJ
Car: 1990 240sx
I had those same wheel locks on a civic I acquired about 3 years ago. I found the key at my local Autozone. If you have trouble finding that key let me know. I still have mine some where around the house I can mail it if you like. Good luck.
maku_gx
Car: 240sx
240TJ wrote:I had those same wheel locks on a civic I acquired about 3 years ago. I found the key at my local Autozone. If you have trouble finding that key let me know. I still have mine some where around the house I can mail it if you like. Good luck.
oh wow! yes please!you're even in the same state. If its ok with you I'll come pick it up. I'm trying to finish my car this weekend so I can actually go to work on monday.
I'm going to summit point WVA in a few minutes for a Lexus event I was invited to.
anyway, try hitting me up at makushikun my AIM
thanks everyone for the ideas. I'm about to be done with this. if can't get the key ill try what r3v_v3ng3 said.
thank you!!6-28-08
maku_gx
Car: 240sx
well this guy never replied, but it dosnt matter cuz i found the key..somewhere inside my car ^_^I know, you wanna hit me badbut im a very distracted person.oh wellthanks anyway for the ideas
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
haha.. good work. i was about to recommend that to you, because it seems mighty stupid to not have the key in the car in case you get a flat (for the person who owned the car b4 u)
Marko
Goldeneagle
Car: 1992 240sx Coupe
maku_gx wrote:well this guy never replied, but it dosnt matter cuz i found the key..somewhere inside my car ^_^I know, you wanna hit me badbut im a very distracted person.oh wellthanks anyway for the ideas
Good thing you found the key. Now it is time you learn what you are dealing with. Wikipedia article on Torx
maku_gx
Car: 240sx
yeah actually, i knew these torx.I tried em, but they dont fit in place.the real key is different...also, itd be sorta stupid to make a special -anti-theft key so it would look like SOME OTHER tool you can find.
racersonly2004
Car: S13 240SX
the 1st guy (98s14inaz) is right those are autozone locks and they do still sell them but there are about 5 diff patterns i recomend taking a photo or realy good look at your locks pattern and mach it up with the ones they have to choose from
maku_gx
Car: 240sx
racersonly2004 wrote:the 1st guy (98s14inaz) is right those are autozone locks and they do still sell them but there are about 5 diff patterns i recomend taking a photo or realy good look at your locks pattern and mach it up with the ones they have to choose from
yeahhh...probably i should SAY AGAIN, that I already FOUND THE KEY and I'm set.
thank you for your feedback though. It is appreciated.(i didnt caps to be rude, but so theyre more visible for the other ppl who are gonna come later n read)
