ayjay »
https://forums.nicoclub.com/ayjay-u5495.html
Sat Apr 17, 2004 6:38 am
remote, ground & power all need to be hooked up to the amp in order for it to turn on... remote wire sends a signal from the deck to the amp, telling the amp when to turn on... as far as where else the remote wire could go on the deck, there isn't... just one wire that comes out of the deck's wiring harness and you need to extend that wire back to your amp... if you've got the remote wire run properly, and the power and ground are hooked up properly to your amp, the only thing else you need is rca's and speaker wire hooked up to the amp and it should work... if it still does not work, then you might want to get your amp checked out
