sldewyz wrote:did you make sure you put the clip in the right way behind the sleeve that connects to the throw out bearing?
E7-S14 wrote:i so bet it was the clutch fork..fail.gonna have to drop the transmission again.
f*** me....that means waiting who knows how long to raise $200 to take it to a mechanic and getting a tow truck, and accepting complete defeat and never working on my car ever again.
I installed it with the hooks of the clips pointing up...and believed me I followed the FSM and spent hours online to make sure I was doing it right because I hadn't anticipated that the clutch fork could be such a potential problem. How does one know if its installed correctly? It snapped in place and seemed to work fine when I pressed the clutch fork lever by hand. It would slide back and forth easily and didn't get stuck.
The symptoms are that when I press the clutch, it stays down and I need to bring it up with my foot. If I move the clutch fork by hand it presses down on the slave cylinder, but its like the slave pushrod can't push it back on its own, it just stays down.
Modified by tmwnn at 11:39 PM 6/15/2009
Modified by tmwnn at 11:47 PM 6/15/2009
