PLX M300, BLITZ DSBC.
drEameRvaJ
Car: 1997 Nissan 240SX SE
Do I have to use the grey and white wire if I will still be running the stock 02 sensor (this 02 sensor will go into my JGS 02 bung). I have another 02 bung welded on my SR20 DP, should I put my wideband to this bung or to the stock 02?
O', also, do I need the resistors? What pin is the 02 heater power/gnd?
Where could I get pressure from for my EBC if my turbo compressor doesn't have a fitting? And on my BLITZ DSBC, it has a plastic hose that I'm suppose to tee for vaccum and back to my control unit (solenoid?), where on the control unit (solenoid) is this vaccum suppose to run to?
HELP!_________________
drEameRvaJ
BUMP.
SeanC
Car: 1993 240sx SE
ok for your first question no you do not have to use the wideband or narrowband output from the m-300 if you are going to use the stock narrow band sensor. i am using no resistors here and mine works fine.
as for the second question. i have no idea.
drEameRvaJ
So if I read what you said correct, I don't need to hook up the grey or the white wire if I"ll still be using the stock 02 sensor and the wideband 02 sensor on the SR20 DP.
SeanC
Car: 1993 240sx SE
no.
drEameRvaJ
THANKS FOR REPLYING! I appreciate it a lot!
drEameRvaJ
No fitting on turbo, where else could I get pressure source (I need two, one for WG and one for EBC, or could/should I tee it off for the two of them, ). Tap intercooler pipe (cold or hot?) with brass fitting's?
Anyone?
drEameRvaJ
BUMP...
sliderdie001
Car: 1995 240
You could always go to the intake manifold and get a vaccum source from there
drEameRvaJ
sliderdie001 wrote:You could always go to the intake manifold and get a vaccum source from there
EBC/WG needs pressure. I heard if you use vaccum for the WG it will wear out the diaphargm.
Could/should I use one fitting and tee it off for both the EBC and WG?
drEameRvaJ
The boost gauge see's pressure doesn't it? My boost gauge is hooked up to the brake booster on a vaccum block, I have a extra fittig on my vaccum block. Could I use this extra fitting for my EBC and WG? Or is the BB just vaccum and not PRESSURE?
ANYONE?
drEameRvaJ
Whoa.. No one.
Jookmasta
sorry for the lack of help, people must be on spring break or something. use this link to help sort out ur issues............
http://www.sr20tuning.com/ebc.html
Modified by Jookmasta at 10:36 AM 4/9/2007
