rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Fri Apr 08, 2005 2:54 am
All u are doing is REMOVING the stock O2 sensor and placing that WIDEBAND sensor in its place..!!
Then I think its the white wire that you would feed back to the ecu to make it think the O2 is still there. This is the wire that has the narrowband signals for the ecu...
The gray wire i believe is the wideband output that u would hook up to the OPTIONAL 52mm pillar gauge that they sell...
I can be wrong about the 2 colors but thats what they are for..
I have the same unit, except for mine does not have the display on that black box, my display is an actual 52mm pillar mount gauge..
