I have never seen any firm numbers. It'd be hard to come up with any, most likely, as the margin of variance between 89 and 91 is probably small enough to fall within the range of dyno variances (maybe 15hp ish, I'd guess, but that's just a blind guess).
allensteiner wrote:it's more about the quality of premium vs any lower grade. you can add stuff to gas to give it more octanes than premium but it'll still be crappy fuel. premium fuels are designed for a good burn but also to keep the fuel system clean. shell, chevron and phillips/conoco are some of the best manufacturers.
It's worth noting that this depends heavily on the station you're getting your fuel from. Some brands only put detergents (or only put their best detergent) in their premium fuel. Others, like Chevron, put the same detergents in all grades. Shell's new "nitrogen enriched" detergent (which appears very similar to techron from what I've researched) is also now found in all 3 grades. Of course, you can always run a bottle of Techron or Redline S-1 every few fill-ups and get close to the same benefits even with crappy low-octane fuel. But as noted above, you're not likely to save any money and you're certainly not saving any time or effort.
