JJ240 »
https://forums.nicoclub.com/jj240-u4459.html
Tue Apr 01, 2003 2:06 pm
You only run vacuum lines to a turbo if its internally wastegated. And Earls makes oil line stuff like SS braided feed line, and the return fittings. I made a post a little while ago of exactly where the oil feed comes from. If you have an externally wastegated turbo you run the vacuum from any vacuum line (intake manifold to Fuel pressure regulator) spliced to the wastegate. I think if its internally wastegated you can hook it straight into the turbo. But really if you had searched I made the post about the oil lines, and a post about the wastegate vacuum lines shortly ago which you could have found easily/
