Finishing up on my SR swap in a 92 hatch. I running an ARC smic and the original T25 but this is my first turbo car so I'm learning as I go. Unfortunately hard to find info on the stock set ups since most stuff seems to about front mounts. I just wanted to verify where these two lines go off the intercooler.
I have an apexi intake on the way, I assume the large line plugs into that. The small hose appears to come off the stock BOV, where does that go? Amayama parts diagram shows I have to run that all the way over to the throttle body. That seems like a LONG way to go but is that correct? It also shows it T's off to an unnamed discontinued solenoid. Is that solenoid needed? I'll be running the wastegate directly to the charge pipe for now until I figure out the boost controller situation.
