Plugs and wires
[GoaTSLonG]
I'm gonna change out my plugs and wires on my SR, question is what is the correct gap and heat range i should get. I was planning on getting NGK Platinum or Iridium plugs mean for a 94 S-ER does that sound right? also i want to buy some NGK wires what size should i get?
Quick240
[GoaTSLonG] wrote:also i want to buy some NGK wires what size should i get?
Are you using a JWT programmed ECU and a distributor on your SR? If not, you should take a closer look at what's connected to the spark plugs. ;)
[GoaTSLonG]
hahahahahaha i have no idea what the **** i was thinking haha sorry, i was just thinking hmm maybe i should give my car a tune up, and what comes first in a tune up usually is plugs and wires haha. ignore the 2nd half of my first post.
SpeedRacer1
Car: 1990 240SX, G35
1mm. no need for the expensive plugs, just get stock NGK BKR7E-11.
If your tuning up, do filters and stuff too. Fuel, oil.
[GoaTSLonG]
so the NGK BKR7E-11's are what i should use on my SR? What should i gap them to? .30? .29?
SpeedRacer1
1mm
Cyberkreig
Car: 1993 Nissan 240SX SR
.028 is stock
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
http://www.phase2motortrend.com/inprer.html phase2 says .030, and they know their stuff.
