plugging the water port on the block?
meet07
Car: 89 180sx rb25det
Im putting my bigger turbo back on and I forgot what i did about the coolant port coming off the block. The new turbo is oil cooled only? What do u guys suggest? Im assuming a plug but I dont think its npt?
Any ideas
meet07
Doing some research its seems the oem banjo fitting in the block M14x1.50. I'm gonna try a basic drain plug from my local auto parts store
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
thats what I did and never had any leaks. I think I put some RTV on it and threaded it in
gawdzilla
Car: none
Technically you should use a washer with the bolt. You can probably re-use one of the crush washers from the banjo fitting. or an oil drain bolt/washer combo should work.
meet07
I ended up using a oil sending unit I had lying around from my Saturn..lol no leaks :)
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
I found an oil pan drain plug with washer and I used it on my rb26 block and works perfect and is much cheaper then a oil sending unit for a saturn lol.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Install. Screw thread sealant. Few $ at autozone
RRRRB
Car: 98 RB powered S14
HxC_Nismo wrote:I found an oil pan drain plug with washer and I used it on my rb26 block and works perfect and is much cheaper then a oil sending unit for a saturn lol.
/Thread
