Plugging the heater hoses?????
200sx SE-aRmed
Car: Nissan 200sx SE-R/ S13 240sx
Does anyone have their heater hose plugged? If so how did you go about dling it...What did you use for plugs? Where did you plug them, hose hardline...? Will it have any ill effects?
Thanks for any help im tryning to get this done so i can finally put my motor in.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Just plugging them would probably enable air bubbles to accumulate there. What I would do is connect the two hoses together when you pull it off from the fire wall.
itsRaine
Car: Keira Knightly, the Lakers, and Keira Knightly.
Silvia007 wrote:Just plugging them would probably enable air bubbles to accumulate there. What I would do is connect the two hoses together when you pull it off from the fire wall.
Yup... thought stuff like that was common sense, heh
200sx SE-aRmed
Stupid question sorry guys but thanks anyways.
gtune4
Car: toonah
since you are in fl, you should be fine! i froze my *** of for one winter because the heater core is a ***** to get to! you have to take out the whole dash on s13.
like they said, just connect the two together, i did it and it works, just reaaaaly cold in winter. hehe
