s73 »
https://forums.nicoclub.com/s73-u119260.html
Fri Oct 09, 2009 7:44 pm
thanks for all the replies guys!
oh ya, about the filler plug, its not like the drain plug for which it has a square female plug, the fill plug its a square male plug, tried to use a adjustable wrench but it seems like it would slip and strip the plug....just wondering if there are any tricks to it...
i want to leave the sensors in but its not leaking from the threads, its actually leaking through the sensors....so teflon tape on threads wouldnt help. Anyways, i guess those sensors are coming out when i change my MTF, so just cut the wires remove the sensors and seal it? no need to do any other wiring work??
BTW do any of you guys know what thread/pitch bolt to use to plug those sensors?
thanks again guys
Modified by s73 at 10:54 PM 10/9/2009
