Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Mon Jun 11, 2007 1:30 pm
OMG....are you serious????
Well no kidding the cap doesn't rotate. There is a rotor inside the cap that spins. The curved arrow indicates the direction of travel for the rotor...which is counterclockwise. Connect your wires from the distributor cap to the sequence of spark plugs I indicated (1-3-4-2).
NOte that some wires will be longer than others and this may require a bit of measuring before making the connections.
