Checkered-Member »
https://forums.nicoclub.com/checkered-member-u10193.html
Tue Jul 13, 2004 7:07 am
Not all cylinders are born equal, for example, the two middle cylinders run a little hotter, then the rest, also (on my alti) #4 gets the most air while #1 gets the least because, if you have a turbo manifold that’s not perfectly equall, or a log style, the cylinder that has the long runner will run leaner then the cylinder with a shorter runner. Also compression varies slightly from cylinder to cylinder.
Are all these variations big enough, so that every spark plug will be gaped a little differently?
