180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jan 22, 2005 10:07 am
Your lack of a thermostat would keep engine temps way too low. Your ECU would keep dumping more fuel to try to raise the motor temperature. Besides, it's winter why the hell would you run your motor without a thermo? It wouldn't stop overheating or something? If so, bleed the coolant properly with a thermo installed before going onto my next suggestions.
Check out the O2 sensor. You might want to get a new set of plugs at the same time if they're fouling. See if the motor warms up like it should. When it does (now that you've got a thermo installed) check your idle speed. MT's idle speed is listed under the hood. After that, check your timing. Another thing to do, although not necessarily the culprit, is to clean the MAFS. If you've still got issues with your motor, it could just be a leaky injector.
