skypad wrote:
Will 95'+ injectors fit in a 91' without modification?
Nope, you'll need to do one of the following things:
A) Send your lower plenum (or a 90-94 core so you reduce your downtime) to JWT for machining. Buy 1995+ fuel rails and 95+ injectors, isolators and insulators. You also need to buy the 95+ connectors, and cut and solder/crimp them to your existing harness.
2)
Get the retrofit kit from Z1 and you can skip the new fuel rails and plenum machining.
III) For the best performance, you'll want to get the 300° Fuel Rails with 95+ injector connectors. No machining and significantly better fuel flow over stock.
300° kit at IPP.com(includes 615cc/min injectors You'll also need the barbed hose adapters linked
here
Keep in mind, if you go with injectors larger than stock (larger than 370cc/min) you'll need to get the EPROM in your ECU reflashed. That usually costs about $100. This is definitely recommended if you plan on doing any kind of upgrades in the future, especially turbos.
Courtesy does have the OEM 370cc/min 95+ style injectors in stock, so even doing a simple 95+ conversion and keeping the same flow rate is possible.
In my 8 years of Z ownership, I haven't found better write-ups than those on these two pages
here and
here.
When I did mine years back, I did the 95+ rails, machined plenum, new connectors and 740cc/min Nismo (Nissan aftermarket) injectors. You also have to machine the bridge on the upper plenum to allow clearances for the #1 injector plug (this is true with any method of using 95+ injectors on a 90-94 plenum). When I pulled my engine in this Z and replaced my EFI harness, I got a 1995 EFI harness so they plugged directly into the injectors. Works great in both configurations.
