pls help id these pieces found in oil pan!
mizono
As the title states I found this in my oil pan after removing it today.
the red material feels like rubber, perhaps this was a sensor? I'm surprised my motor hasn't seized while this part went through it. Oh and this broken piece is aluminum because my magnet wasn't able to pick it up.
I have no idea wtf this is, but its metal and I found it in the oil strainer/pick up, I'm glad this piece didn't go through the oil pump.
SpeedRacer1
Car: 1990 240SX, G35
The flat circle is a valve shim from the head. Better check out whats going on under the valve cover.
duffman1278
Car: 89 240sx Hatch, the wildcats!
I dunno wtf that is either but try looking in the FSM it might show a pic of it, but I highly doubit. Thats some wierd as* sh**
Hijacker
Car: '92 240sx Convertible
'94 F-150
The spherical thing is casting for the bolt holes on the upper oil pan. The red stuff is silicon. Since it's not grey, I assume someone has had the upper pan off and when they reinstalled it, overtightened that particular bolt (possibly used an air tool) and it eventually fatigued the casting and broke off.
burnin240sx
now would be a good time to check all bearing surfaces before you have serious engine damage.
bgsr240
Car: 90 240sx hatch sr20det redtop gt28rs-sold 89 240sx hatch S14 sr20det blacktop
That is awesome LOL! Shim in the oil pan LOL!
slik_s13
Car: 1990 nissan 240sx hatch back
yup thats a valve shim.. the other one hijacker seems to know, i havent seen anything like that before. but it does make sence of where he explained it came from. your definately going to want to check things out in the bottom end now. gl
fast_s13
good luck with all that
