I have S13(93) and ordered megan racing tension rods for S14.(I did not realized until managed to install them myself).Megan's website states that a S14 tension rod is 1 in longer.
Without alignment check, can anyone tell the effect of extra length? (The megan's pillow-ball tension rod is adjustable in length. So I assume even getting tension rod S13 and extended for an inch, it might result in the same.)
After a short ride, I notice that steering response is quicker so I assume that extra 1 inch increased caster angle. (Factory spec for the front cast angle is withing 6 - 7.5 degree)
Modified by JoeKakeyoro at 12:26 AM 4/7/2007
