gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sat May 08, 2010 2:54 pm
From experience, buy a stock replacement clutch, either an Exedy online or from the local parts store. It should not run you more than $120 and should be the complete clutch kit to include disc, pressure plate throwout/release bearing and a pilot bushing. Unless you are putting down more than stock numbers plus bolt-on's, a stock clutch will serve you well. Plus my clutch kit from Oriellies has a lifetime warranty which I have used to replace my clutch no less than 3 times to date.
Replace the flywheel with an F1 or XTR from ebay for another $180. The flywheel checks in at a bit over 12lbs. You will notice a difference on take off and especially on the high end of the taco-meter. And lastly, purchase the 1 piece steel braided clutch line that connects the master cylinder to the slave eliminating the annoying dampener box. This last thing gives you much better pedal feel and it becomes rediculously easy to bleed the clutch system.
At some point down the line invest in a proper short shifter. It does not have to be a B&M but it should be the complete shifter that replaces the base plate. These can run from $30 to well over $100. Make sure to get a gasket as well. It is much easier to replace the gasket than try and install the shifter using silicone.
And for the record, yes I have used a B&M short shifter and I replaced it with an Ebay piece that does not RATTLE at any rpm. I believe it was a Mokeeh, but I would not be surprised if it was a Megan shifter in a different box. Well that is my suggestion. As with all things, take it with a grain of salt, and do your own due diligence. Good luck.
