Jged99 »
https://forums.nicoclub.com/jged99-u37783.html
Sat Feb 17, 2007 10:56 pm
I have a PLMS daughterboard installed in my ECU. It uses two eproms. I am having trouble getting this stuff to work. I am just trying to run ONE map on the eproms. Do I have to set any of the jumpers? IE: (J1, J2)??? When I burn the chips do I have to set them at a certain address? Another problem I am having is with running two emulators. I have all the necessary hardware like a two serial to one usb converter, two pocket romulators. I have been able to get LiveEdit to recognize both of them but any changes I make don't do anything . Also I can make changes and burn them straight to chips and still nothing happens.The car is staying at 10.0's AFR's at idle. I just need a walkthrough on how to set things up to run two emulators. I have tried everything and I must be overlooking something. Any info would be greatly appreciated.Thanks.
